6.3(4) command not converted to 7.0
aproductions
I have searched through all the documentation i could find as to why my commands for all my site to site keys were not converted to 7.0:
EXAMPLE
isakmp key xxxx add 172.x.x.1 netmask 255.255.255.255 no-xauth no-config-mode
were not converted into 7.0 commands.
also the docomentation is a little vague on what is should actually be.
i am thinking that it should now read
tunnel-group 172.x.x.1 type ipsec-l2l
tunnel-group 172.x.x.1 ipsec-attributes
pre-shared-key password
(AFTER TUNNEL GROUP IT SHOULD BE THE PEER IP?)
and also that if i was having dhcp remote peers coming into my hub which used to read
isakmp key password address 0.0.0.0 0.0.0.0 no-xuath no-config-mode
what should this now be?
as a result of this i've had to back out and replace with a different firewall until i can sort this out.
thanks for any help
sam
owensgl
The command is
you must do a wr net before you upgrade for you can have the passwords.
Greg owens
