802.1x and Cisco IP phones
pthaynes
I have 802.1x configured on a Cisco 2950 switch. On ports where I have PCs plugged into the data port on the IP phones users sometimes get placed in the guest vlan. If they shut down their attached PC and then unplug the network cable (the one between the switch and the phone), then re-plug in the cable and boot their PC it seems to authenticate them again.... sometimes. The config for the ports with phones configured is as below:
interface FastEthernet0/4
switchport access vlan 4
switchport mode access
switchport voice vlan 200
switchport port-security
switchport port-security maximum 2
no ip address
dot1x port-control auto
dot1x host-mode multi-host
dot1x guest-vlan 3
spanning-tree portfast
Does anyone have a possible fix or work around?
Thanks in advance,
Peter
15 Replies 15
I was referring to Cisco phones. That firmware is shipping. Cisco phones have the caability of sending an EAPOL-Logoff on behalf of the PC when a PC unplugs to address your issues discussed here.
As for MSFT, there is no way to configure the supplicant (even through the registry) to send EAPOL-Logoff without losing machine-auth ability. In the upcoming Vista platform, it will not send EAPOL-Logoffs at all, due to percieved security threat. I invite you to discuss this with MSFT further if you need details, or need EAPOL-Logoffs to be sent, etc.
Hope this helps,
