access-list problem
rchavesm
Hello , I have a problem with PIX Firewall Version 6.0(1), the problem is:
I have a pix with 3 interface inside,outside and dmz,
ip address outside x.x.x.2 255.255.255.248
ip address inside 200.115.10.10 255.255.255.0
ip address dmz 192.168.6.28 255.255.255.0
I need to make an acl where only 3 PC's in the inside access the server installed in the dmz,with an ip public, but the acl doesn't work.
Following is the acl, but I have change the IP addresses.
access-list 108 permit ip 200.115.10.0 255.255.255.0 172.16.1.0 255.255.255.0
access-list 108 permit ip 200.115.10.0 255.255.255.0 200.105.10.0 255.255.255.0
access-list 108 permit ip 200.115.10.0 255.255.255.0 200.105.20.0 255.255.255.0
access-list 108 permit ip 200.115.10.0 255.255.255.0 200.105.30.0 255.255.255.0
access-list 88 permit ip 200.115.10.0 255.255.255.0 200.105.10.0 255.255.255.0
access-list 88 permit ip 200.115.10.0 255.255.255.0 200.105.20.0 255.255.255.0
access-list 88 permit ip 200.115.10.0 255.255.255.0 200.105.30.0 255.255.255.0
pager lines 24
logging on
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip audit info action alarm
ip audit attack action alarm
ip local pool test 172.16.1.1-172.16.1.254
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address dmz 0.0.0.0
pdm history enable
arp timeout 14400
global (outside) 1 interface
global (dmz) 1 192.168.6.10
nat (inside) 0 access-list 108
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) x.x.x.5 192.168.6.30 255.255.255.255
static (inside,outside) x.x.x.6 10.10.70.1 netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.4 200.115.10.16 netmask 255.255.255.255 0 0
static (dmz,outside) x.x.x.5 192.168.6.30 netmask 255.255.255.255 0 0
conduit permit tcp host x.x.x.6 eq lotusnotes any
conduit permit tcp host 2x.x.x.4 eq www any
conduit permit tcp host x.x.x.4 eq lotusnotes any
conduit permit tcp host x.x.x.5 eq www any
conduit permit tcp host x.x.x.5 eq domain any
conduit permit icmp any any
conduit permit tcp host x.x.x.5 eq https any
conduit permit tcp host 2x.x.x.5 eq 21010 any
the public IP that I need to access from the inside is x.x.x.5
The ACL you're providing will still do the same thing when you shorten it to this:
access-list 110 deny tcp host 200.115.10.0 host x.x.x.5
access-group 110 in interface inside
(this one would not work though, because host 200.115.10.0 *watch the zero* probably does not exist)
Assuming that your dmz has a lower securitylevel then your inside interface, you have to remember that if packets are travelling from higher to lower level security the PIX does the following:
1) if it is an existing flow, let the packet through
2) if it is not an existing flow, check ACL
3) if ACL denies, then drop the packet, if ACL permits, let packet through
4) if ACL does not match at all, let the packet through (since it is from high to low level security)
But I'll guess this is not what you want to achieve.
I think you need something like this:
access-list 110 permit tcp host 200.115.10.40 host x.x.x.5 eq www
access-list 110 permit tcp host 200.115.10.41 host x.x.x.5 eq www
access-list 110 permit tcp host 200.115.10.42 host x.x.x.5 eq www
access-list 110 deny ip 200.115.10.0 255.255.255.0 x.x.x.0 255.255.255.0
(assuming you have a 24-bit subnet on your dmz)
access-list 110 permit ip any any
This will let the three inside hosts access the server x.x.x.5 on you dmz with HTTP, let no one else from the subnet 200.115.10.0/24 to the dmz, and permit all other outside traffic.
Hope this helps.
Kind Regards,
Leo
l.mourits
Level 5
Level 5
First thing I noticed in your config is that you are using conduits and ACL's at the same time. This is not recommended! So, thirst thing I would do is get rid of the conduits and convert this to an ACL.
Second thing is that I see that you're having two ACL's (108 and 88) and they are not bound to an interface (with the access-group command), so, if this is your whole config then the ACL's are never used.
Question: What is the use of ACL 88 (sounds to me like a anti-spoofing ACL, but there are easier ways to prevent IP-spoofing on the PIX with using IP verify reverse path)
Remember, Cisco recommends to use only ACL's (or conduits only, but conduits are not the recommended way anymore).
Then you have to remember that you when you build an ACL, the PIX does only support inbound ACL's, and the ACL is bound to an interface using the command access-group.
(example: access-group 108 in interface dmz)
You do not have to concern about return traffic, cause the ASA algorithm within the PIX will take care of this (that is, if all the right translations are in place).
Finally, do not test with ICMP (ping), because ICMP is not handled by the ASA, so the returning echo replies does not pass the PIX (unless you create a rule in your ACL which does permit ICMP echo replies)
Better to use TCP/UDP for testing, cause these are statefully inspected and are handled by the ASA.
Hope this helps.
Kind Regards,
Leo
Thanks you, for your answer
I'm goint to take the conduit off and I will use the following ACL, do you think this will work or I have to make some changes.
Can you help me?.
Hope this helps.
Kind Regards,
Leo
thanks all
