ACL question
rolandshum
I'm considering putting this ACL on the inside interface to prevent the following ports from going out to the 'net. I don't want to interrupt the other IP traffic and was hoping for just a sanity check to make sure I'm doing this one right. I'd hate to mess up my inside interface.
access-list 130 deny tcp any any eq 135
access-list 130 deny udp any any eq 135
access-list 130 deny udp any any eq netbios-ns
access-list 130 deny udp any any eq netbios-dgm
access-list 130 deny tcp any any eq 138
access-list 130 deny tcp any any eq netbios-ssn
access-list 130 deny tcp any any eq 445
access-list 130 deny tcp any any eq 593
access-list 130 deny tcp any any range 3127 3199
access-list 130 permit ip any any
I'm not sure if I should put the "permit ip any any" at the end of the ACL or at the begining.
jackko
Level 7
Level 7
the entry permitting any any must be placed at the end of the acl, as the acl works in order.
jackko
Level 7
Level 7
Thanks I'll be implimenting that this week. I was afraid that if I put the any any at the end it would just negate all the previous lines.
Hi!
can someone help me and explain what I'm doing wrong by setting up ACL's?
It semms that on my SG 300-52 the following setup blocks all acces on port 3 instead of blocking only for MAC xx:xx:xx:xx:5f:b6
many thanks in advance!
