ACL question
Ahmede
I have a router with an interface facing the internet. I want to use this router to setup LAN-to-LAN IPsec VPN's. I want to implement an ACL on that interface to protect my router and network. I want to allow only VPN traffic. What the access list should look like (assuming I'm using the ip address 1.1.1.1/28 on my router interface)
Thanks in advance..
abdel_n
Hi Ahmed,
When filtering at the edge, there is no too much to see:
IKE protocol --> idp 500
IPSec protocols:
ESP protocol --> ip protocol 50
AH protocol ---> ip protocol 51
For NAT transparency:
udp 4500 or tcp (port number has to be configured)
So the acces-list looks like:
Router(config)#access-list 100 permit esp 1.1.1.1 0.0.0.15
Router(config)#access-list 100 permit ahp 1.1.1.1 0.0.0.15
Router(config)#access-list 100 permit udp 1.1.1.1 0.0.0.15 eq 500
Router(config)#access-list 100 permit udp 1.1.1.1 0.0.0.15 eq 4500
!!!And assign it to the interface to which the crypto map is bound
Router(config-if)#ip access-group 100 in
You can set also a symmetric acl at the IPSec peer in other side.
I hope this will help.
Have a good work!
AJN
