ACLs on Catalyst 2940
admin_2
Level 3
Level 3
Hi Guys,
I wan´t to configure the ACLs on the catalyst 2940. After creating the ACL I can´t apply it to any interface since I don´t have the ip access-group command available to any interface.
What should I do ?
sstudsdahl
Level 4
Level 4
From the release notes, it appears that you can only apply the ACL to a management VLAN interface or for use with an access-class statement. Here is a link to the release notes:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2940/12120ea1/ol503501.htm
The statement is located under the Cisco IOS Limitations and Restrictions section.
