08-11-2005 07:43 AM - edited 03-09-2019 12:06 PM
I have a site to Site tunnel between a PIX 506E and a PIX 515E that goes between two locations. I can see each side via ip and can connect to each side with PCAnywhere etc... The problem I am having is attaching computers or servers to the domain from the remote location. I keep getting RPC is Unavailable. I am running version 7.0.(1)5 here on the PIX 515E. Does anyone have any ideas on how I can allow or pass traffic to allow these machines to connect and replicate?
Any and all help is much appreciated.
Aaron
08-11-2005 08:56 AM
Hi Aaron,
I would consider at specifying exact ACL's allowing to and the ports used such 138 and 139 for Netbios and so on (cannot remember any other Windows ports used), or specify an ACL allowing all IP between the two groups.
Andrew.
Andrtew
08-11-2005 09:29 AM
I am a little new at the PIX. Can you tell me how I can accomplish that?
Thanks!
Aaron
08-11-2005 09:59 AM
Hi Aaron,
I really doubt this is related to your access-lists.
Normally, all traffic that is protected by the tunnel is allowed to pass through with the "sysopt connection permit-ipsec" command (it bypasses the access-lists).
You also said that you were able to access the server via PC Anywhere; is that using the private address or a public address? If it is with the public address, try with the private address to make sure the traffic is actually going through your VPN tunnel.
Another thing might be that one end of the tunnel has several subnets, and you forgot to protect that subnet on which your domain controller is?
- Alex
08-11-2005 10:07 AM
I was accessing the Nat'd IP address on the other side so I know the tunnel works. I also see under IPSEC rules it says protect my LAN (PIX SIDE) and Offsite (Remote Side) service is IP.
Any ideas?
08-11-2005 11:43 AM
Could you provide us with your pix's configuration? It would help greatly in determining the cause of you problem.
08-11-2005 12:12 PM
Let me try this.
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit Cp any host X.X.X.X7 eq smtp
access-list outside_access_in extended permit Cp any host X.X.X.X eq smtp
access-list outside_access_in extended permit udp any host X.X.X.X51 eq 2233
access-list outside_access_in extended permit udp object-group BOS host X.X.X.X51 range 10025 10027
access-list outside_access_in extended permit icmp host BOSwubos any
access-list outside_access_in extended permit udp host BOSwubos any eq snmp
access-list outside_access_in extended permit udp host ThomsonOne X.X.X.X 255.255.255.0 eq 4900
access-list outside_access_in extended permit Cp object-group BOS any object-group BOS-mgmt-Cp
access-list outside_access_in extended permit udp object-group BOS any object-group BOS-mgmt-udp
access-list outside_access_in extended permit Cp object-group BOS any eq pcanywhere-data
access-list outside_access_in extended permit Cp ecsbos 255.255.254.0 host X.X.X.X0 eq pcanywhere-data
access-list outside_access_in extended permit udp ecsbos 255.255.254.0 host X.X.X.X0 eq pcanywhere-status
access-list outside_access_in extended permit Cp ecsbos 255.255.254.0 host X.X.X.X1 eq pcanywhere-data
access-list outside_access_in extended permit udp ecsbos 255.255.254.0 host X.X.X.X1 eq pcanywhere-status
access-list outside_access_in extended permit Cp object-group C host X.X.X.X eq ssh
access-list outside_access_in extended permit Cp Net-SendIO 255.255.255.224 host X.X.X.X4 object-group SendIO
access-list outside_access_in extended permit Cp host BLPMDSGW host X.X.X.X eq 6464
access-list outside_access_in extended permit udp host ntp2. host X.X.X.X4 eq ntp
access-list outside_access_in extended permit udp Net-SendIO 255.255.255.224 host X.X.X.X4 object-group SendIO-UDP
access-list outside_access_in extended permit Cp BOS3 255.255.255.0 host X.X.X.X30 eq pop3
access-list outside_access_in extended permit Cp host advisorware host X.X.X.X0 eq pcanywhere-data
access-list outside_access_in extended permit udp host advisorware host X.X.X.X0 eq pcanywhere-status
access-list outside_access_in extended permit ip BOS2wells1 255.255.255.0 any
access-list outside_access_in extended deny ip any any
access-list dmz_access_in extended permit ip host smtp any
access-list dmz_access_in extended permit ip host C_dmz any
access-list dmz_access_in extended permit ip host p2prouter any
access-list dmz_access_in extended permit ip ChomeX.X.X.Xany
access-list dmz_access_in extended permit ip ChomecoX.X.X.Xany
access-list dmz_access_in extended permit icmp any any
access-list dmz_access_in extended permit Cp host C_dmz host C_LAN eq ssh
access-list dmz_access_in extended permit Cp host C_dmz host C_LAN eq ftp
access-list dmz_access_in extended permit Cp host SendIO host MAIL eq smtp
access-list dmz_access_in extended permit Cp host SendIO host BOS2DC2 eq 3268
access-list dmz_access_in extended permit udp host SendIO host BOS2DC2 eq 3268
access-list dmz_access_in extended permit Cp host SendIO host BOS2DC2 eq domain
access-list dmz_access_in extended permit udp host SendIO host BOS2DC2 eq domain
access-list dmz_access_in extended permit ip host SendIO any
access-list dmz_access_in extended permit ip host smtp_new any
access-list dmz_access_in extended deny ip any any
access-list inside_nat0_outbound extended permit ip X.X.X.X255.255.255.0 BOS2wells1 255.255.255.0
access-list outside_cryptomap_20 extended permit ip X.X.X.X255.255.255.0 BOS2wells1 255.255.255.0
access-list inside_access_in extended permit ip X.X.X.X255.255.255.0 any
08-11-2005 12:14 PM
Here is some more:
static (inside,dmz) X.X.X.XX.X.X.Xnetmask 255.255.255.0
static (inside,outside) X.X.X.X BOS2FS netmaskX.X.X.X
static (inside,outside) X.X.X.X BOS2SQL netmaskX.X.X.X
static (inside,outside) X.X.X.X MAIL netmaskX.X.X.X
static (dmz,outside) X.X.X.X7 smtp netmaskX.X.X.X
static (inside,outside) X.X.X.X50 gigeswiCh1 netmaskX.X.X.X
static (inside,outside) X.X.X.X47 mvswiCh netmaskX.X.X.X
static (inside,outside) X.X.X.X51 netstructurevpn netmaskX.X.X.X
static (dmz,outside) X.X.X.X C_dmz netmaskX.X.X.X
static (inside,outside) X.X.X.X45 BOS2wells netmaskX.X.X.X
static (inside,outside) X.X.X.X30 Audix netmaskX.X.X.X
static (inside,outside) X.X.X.X31 definity-clan1 netmaskX.X.X.X
static (inside,outside) X.X.X.X32 definity-clan2 netmaskX.X.X.X
static (inside,outside) X.X.X.X33 definity-medpro netmaskX.X.X.X
static (dmz,outside) X.X.X.X46 p2prouter netmaskX.X.X.X
static (inside,outside) X.X.X.X44 adtran netmaskX.X.X.X
static (inside,outside) X.X.X.X0 Cserver netmaskX.X.X.X
static (inside,outside) C_LAN C_LAN netmaskX.X.X.X
static (inside,outside) X.X.X.X BES netmaskX.X.X.X
static (dmz,outside) X.X.X.X4 SendIO netmaskX.X.X.X
static (dmz,outside) X.X.X.X smtp_new netmaskX.X.X.X
static (inside,outside) X.X.X.X BOS2DC2 netmaskX.X.X.X
static (inside,outside) X.X.X.X BOS2DC1 netmaskX.X.X.X
static (inside,outside) X.X.X.X1 BACKUP netmaskX.X.X.X
static (inside,outside) X.X.X.X0 AW netmaskX.X.X.X
static (inside,MV) X.X.X.XX.X.X.Xnetmask 255.255.255.0
static (MV,test) X.X.X.X X.X.X.X netmask 255.255.255.0
static (MV,dmz) X.X.X.X X.X.X.X netmask 255.255.255.0
static (inside,outside) X.X.X.X FS1 netmaskX.X.X.X
static (inside,outside) X.X.X.X1 CDEVSQL netmaskX.X.X.X
08-12-2005 05:26 AM
Bump.
Thanks!
08-16-2005 09:25 AM
Still looking for help on this one.
Aaron
