AH and ESP used in both phase 1 and 2?
ciscoforum
AH and ESP is the protocol used in IKE phase 2 when establishing IPsec SA or also used in the IKE phase 1? If not, what IP packet format used in the IKE phase 1? Thanks
hemendoz
You asked
"AH and ESP is the protocol used in IKE phase 2 when establishing IPsec SA or also used in the IKE phase 1?" AH and ESP are only used after the Phase 2 SAs have been built.
"If not, what IP packet format used in the IKE phase 1?" UDP 500 or 4500 (if NAT-T is used)
Hope that helps! If so, please rate.
