Allowing port 3389
tpopejr
I want to allow RDP to a Windows server thru a PIX.
I've typed the following but it still doesn't work:
static (inside,outside) tcp 66.77.88.1 3389 192.168.1.100 3389
access-list allow_rdp permit tcp any host 66.77.88.1 eq 3389
access-group allow_rdp in interface outside
clear xlate
It accepts the commands but doesn't allow me to connect thru RDP.
Questions:
1). Is this port supported?
2). Is the syntax correct?
3). What command can I use to see what's happening at the PIX (what debug command)?
Tom
jmia
Level 7
Level 7
Tom,
Your command syntax is OK, port 3389 is supported for RDP. My question to you is, do you see any 'hit counts' for port 3389 on your outside ACL? The reason for asking is so that we can eliminate any internet routing issues.
Can you try to telnet from the outside to your public IP on port 3389 - does it connect??
Is your Win server running terminal service?
Let me know the answers to the questions above and we can look at this further, also it would be good to see your pix config (if you do post it here please take out any sensitive info).
Jay
jackko
Level 7
Level 7
"sh xlate | in 192.168.1.100" to verify the static statement, and you should see
Global 66.77.88.1 (3389) Local 192.168.1.100 (3389)
another thing to verify is whether the terminal service is running on .100 as expected. please verify by establishing a rdp connection locally from a pc with ip 192.168.1.x.
tpopejr
Sorry for the delay.
I corrected the issue. I forgot to enable RDP on the server (doh!).
Thanks for the replies.
Tom
