no communication between inside and dmz
stephtchoko
Level 3
Level 3
Please,
i configure pix to locate the server on dmz interface and host on inside interface.
the problem is that the host on inside interface cannot reach the e-mail server (196.202.232.17).
This is show run output:
names
access-list accl_dmz permit icmp any any
access-list outside_int permit ip any host 196.202.232.17
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
ip address outside 196.202.232.3 255.255.255.128
ip address inside 172.16.1.1 255.255.255.0
ip address DMZ 172.16.2.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.16.1.0 255.255.255.0 0 0
static (DMZ,outside) 196.202.234.64 172.16.2.2 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.17 172.16.2.3 netmask 255.255.255.255 0 0
static (DMZ,outside) 61.11.234.86 172.16.2.4 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.9 172.16.2.5 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.13 172.16.2.6 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.15 172.16.2.7 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.14 172.16.2.8 netmask 255.255.255.255 0 0
static (DMZ,outside) 66.178.60.9 172.16.2.9 netmask 255.255.255.255 0 0
static (DMZ,outside) 61.11.234.6 172.16.2.10 netmask 255.255.255.255 0 0
static (DMZ,outside) 196.202.232.6 172.16.2.11 netmask 255.255.255.255 0 0
static (inside,DMZ) 172.16.1.0 172.16.1.0 netmask 255.255.255.0 0 0
access-group outside_int in interface outside
conduit permit ip 172.16.1.0 255.255.255.0 any
conduit permit ip any any
route outside 0.0.0.0 0.0.0.0 196.202.234.1 1
route outside 10.2.4.0 255.255.255.0 196.202.234.63 1
route outside 10.2.5.0 255.255.255.0 196.202.234.63 1
route outside 10.2.7.0 255.255.255.0 196.202.234.63 1
route outside 10.2.8.0 255.255.255.0 196.202.234.63 1
route outside 10.2.9.0 255.255.255.0 196.202.234.61 1
route outside 10.2.10.0 255.255.255.0 196.202.234.63 1
route outside 10.2.11.0 255.255.255.0 196.202.234.63 1
route outside 203.192.200.0 255.255.255.0 196.202.234.61 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
from host 172.16.1.24 i make ping to 196.202.232.17 (e-mail server); there are debug icmp trace message:
pixfirewall# debug icmp trace
ICMP trace on
Warning: this may cause problems on busy networks
pixfirewall# 45: ICMP echo-request from inside:172.16.1.24 to 196.202.232.17 ID=
512 seq=14126 length=40
46: ICMP echo-request: translating inside:172.16.1.24/512 to outside:196.202.232
.3/0
47: ICMP echo-request from outside:196.202.234.40 to 196.202.232.17 ID=1280 seq=
3113 length=40
48: ICMP echo-request: untranslating outside:196.202.232.17 to DMZ:172.16.2.3
49: ICMP echo-reply from DMZ:172.16.2.3 to 196.202.234.40 ID=1280 seq=3113 lengt
h=40
50: ICMP echo-reply: translating DMZ:172.16.2.3 to outside:196.202.232.17
undebug all51: ICMP echo-request from inside:172.16.1.24 to 196.202.232.17 ID=51
2 seq=14382 length=40
52: ICMP echo-request: translating inside:172.16.1.24/512 to outside:196.202.232
.3/0
53: ICMP echo-request from outside:196.202.234.40 to 196.202.232.17 ID=1280 seq=
3369 length=40
54: ICMP echo-request: untranslating outside:196.202.232.17 to DMZ:172.16.2.3
55: ICMP echo-reply from DMZ:172.16.2.3 to 196.202.234.40 ID=1280 seq=3369 lengt
h=40
56: ICMP echo-reply: translating DMZ:172.16.2.3 to outside:196.202.232.17
Please, very emergency.
Any help will be appreciated.
Patrick Iseli
Level 7
Level 7
1.) This is normal you cannot connect the DMZ host with his public IP. The PIX Policy does not alow that.
2.) You have disabled NAT between the inside and the DMZ interface.
You should connect to your Email server with his private IP: 172.16.2.3
3.) You could tweak that limitation with the DNS Doktoring feature but it depends on where your DNS server is located, external or internal.
Take a look at this POST
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd65552/0#selected_message
sincerely
Patrick
