06-26-2006 11:17 PM - modifié 03-09-2019 03:24 PM
Is there another way to install the Clean Access Agent without having Administrator privilleges? Coz, there's policy stated that any users on our company can't have administrator privillege.
le 07-03-2006 06:57 AM
The Secure Desktop tries different methods to install itself on Windows client computers until it finds a method that works. The installation is automatic and transparent to the user, however, one of the methods must be available on the client and the user must have privileges to use that method. The installation methods and associated user requirements are as follows:
Table 1 CSD Installation Methods and Requirements
CSD Installation Method Client User Requirement
ActiveX - Administrator privileges
Microsoft JVM- Power-user privileges
Sun JVM- Any user
Exe- Any user with execution permissions.For more refer the following URL
http://www.cisco.com/en/US/products/ps6742/prod_release_note09186a00805f9cb4.html
le 08-07-2006 08:08 PM
Hello Ronald,
How do you distribute software/patches currently? I am guessing you have a software distribution application like Altiris, Bigfix, SMS or some other software similar like this which can uses escalated priviliges to install software. You can distrubute the CCA agent in similar manner. You will need to first use a test pc to download the agent via the web login method. And then you can use this downloaded file to be distributed using one of the softwares above.
Please let me know if this helps.
-Alok
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
