AnyConnect Client CLI Scripting Help?
Gerard Roy
Level 2
Level 2
I need a method/script that will help me launch the anyconnect client from the command line of a windows machine and login to the ssl vpn. Then I need to know if this script can be scheduled in windows scheduler. I have attached what I have so far. This still requires human interaction. Anyone have a better way? (What the hell happend to file attachment capabilities here?)
' FILE: VPN_ON.VBS CREATION DATE: 8/06/2008 AUTHOR: ****
' PURPOSE: AUTOMATE THE CONNECTION WITH THE IPASS/CISCO ANYCONNECT VPN CLIENT
' 8/06/2008 - JA - INITIAL VERSION
' 8/07/2008 - JA - ADDED LOCK WORKSTATION FUNCTION
'Define Contants
Dim strPassword, strVpnClient, strWinDir, colSystemEnvVars, strUserName
'Create Shell Objects
set WshShell = WScript.CreateObject("WScript.Shell")
WScript.Sleep 30000
Set colSystemEnvVars = WshShell.Environment("System")
'Process Variables
'-=Customize your username below.=-
strUserName = "username"
'-=Customize your password below.=-
strPassword = "password"
strVpnClient = "C:\Program Files\Cisco\Cisco AnyConnect VPN Client\vpncli.exe"
strWinDir = colSystemEnvVars("windir")
'Launch VPN Client
WshShell.Run "cmd /c " & Chr(34) & strVpnClient & Chr(34)
'Send Keystokes to VPN Client
WScript.Sleep 1000
WshShell.AppActivate strWinDir & "\system32\cmd.exe"
WshShell.SendKeys "connect isa.site.com{ENTER}"
WScript.Sleep 5000
'-=Send the username=-
WshShell.SendKeys strUserName & "{ENTER}"
WScript.Sleep 1000
'-=Send the password=-
WshShell.SendKeys strPassword & "{ENTER}"
WScript.Sleep 10000
'-=Exit the VPN Client, it wil stay connected.=-
WshShell.SendKeys "exit{ENTER}"
'Lock the Workstation
WshShell.Run "%windir%\System32\rundll32.exe user32.dll,LockWorkStation"
0 Replies 0
