ASDM software won't load
jnix
So I've been fighting with this all day.  I've tried 3 different machines including a server.
Basically when I try to access my ASA 5510 with the ASDM software the software never loads.  So I have tried to access it through the management port https://192.168.1.2 and installed the software.  The software starts up, I enter the password and it connects and loads to 100% but doesn't go beyond that point.  I then try the java applet, and it as well loads up to 100% and says "Please wait, the main is coming up."
I have http server enabled, and asdm image is pointed correctly
As I said, I've tried this on two Windows XP machines and a machine running Server 2008.
I can connect through CLI all day and all night, but I'd rather (read feel much safer) configuring it through ASDM.
Here is some system version info
Cisco Adaptive Security Appliance Software Version 7.0(8)
Device Manager Version 5.0(8)
Compiled on Sat 31-May-08 23:48 by builders
System image file is "disk0:/asa708-k8.bin"
I would suggest you look and see if you meet the system requirements, especially for Java. If you do I would suggest loading a different version of ASDM on the ASA, that always seems to fix the problem you are experiencing.
http://www.cisco.com/en/US/docs/security/asa/asa70/asdm50/release/notes/rn508.html
5 Replies 5
daveyboy1972
I have this same issue. I cannot connect to the console hardwired either.
Im not that great with cisco but i need to get this fixed.
To connect to the console do i need to use a crossover cable?
Could you give me any pointers on how to restore the config from flash using the cli?
you have to make sure contained following settings in your running configuration file:
asdm image disk0:/asdm-xxx.bin
aaa authentication http console LOCAL
http server enable
http xxx.xxx.xxx.0 255.255.255.0 inside
Also, you have to install jdk-6u??-windows-i586.exe or jdk-7u??-windows-i586.exe, don't use the 64-bit version and JDK-8u??.
Aside from trying the latest code, have you checked the security settings on your PCs that you are using. Is there an Anti-virus or firewall that can potentially be stopping a service from running?
Mario
Thank you all for your help and support.
I just yesterday was able to get this situation resolved.
The ASA I came with apparently shipped with a version of the ASDM software that was not compatible.  So when I used the software that came with the ASA it wouldn't load.  I was able to download and install the most up to date IOS and ASDM.bin software onto the ASA and it worked like a charm.
