02-02-2007 09:03 AM - edited 03-09-2019 05:20 PM
I need to buy a firewall with some basic URL filtering. I only need to deny access to some URL and not using a service like Websense or something like that.
I would like to do this with an ISR, like 2800 family, because I don't need anti-x features but only basic firewalling, VPN, and Voice features.
The other option is to use ASA 5520, but I would like to make the simple URL filtering without the need to use CSC module.
Is there any way to to this?
Mario.
Solved! Go to Solution.
02-08-2007 12:42 PM
There is no need to go for an ASA. A 2800 isr will do.
Refer the following url's for more details,
http://cisco.com/en/US/products/sw/iosswrel/ps5460/prod_bulletin09186a00801af451.html
http://cisco.com/en/US/products/ps6643/products_white_paper0900aecd804abb11.shtml
02-08-2007 12:42 PM
02-08-2007 02:56 PM
you can do this on a simple router like an 800 (830/831 router) or a PIX firewall (even the lowest model would work). good luck.
