Block an PC from Switch
abithbasha
Dear All,
I have virus infected PC in the network, I want to block this PC from network, I can shut down the port but if the PC connects to another switch port then it will spread virus, so I have MAC address b870.f400.7979 and I wanted to block this MAC from our network, which ever port this MAC connects then that port should drop this or not allow this on our network
6 Replies 6
shijomon scaria
Port security can be an option for you, but the effort varies according to the size of your network.
Shijo.
It is small office, so can you give me a option or commands how to block it on the network
the PC MAC  address is this b870.f400.7979
Instead of blocking that particular mac, in port security we are adding trusted macs to ports using different methods, and sets the rule if the conditions violates.
Example.
SWITCH(config)# int Gi0/1
SWITCH(config-if)#switchport port-security
SWITCH(config-if)#switchport port-security mac-address 0000.aaaa.bbbb
SWITCH(config-if)#switchport port-security violation shutdown
Refer below document.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25ew/configuration/guide/conf/port_sec.pdf
Shijo.
And the other option is MAC ACLS
Shijo.
Can I have link or commands for MAC ACLS?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_nx-os-cfg/sec_macacls.pdf
Shijo
