Bookmark
Subscribe
657
Blocking FTP connections for specific clients
fahmyaziz
Hi. My core switch has 2 vlan interfaces, vlan85 for users and vlan100 for servers. I would like to allow a few certain IPs from vlan85 users to my FTP server. Can this be done without actually needing to define access to all the other services (my users need access other machines using ssh, telnet, web etc.)
Thanks.
5 Replies 5
Jon Marshall
Assuming you client vlan is 192.168.5.0/24 and 192.168.5.10 & 11 are the clients you want to allow to ftp
access-list RESTRICT permit tcp host 192.168.5.10 host "ftp server ip" eq 20
access-list RESTRICT permit tcp host 192.168.5.10 host "ftp server ip" eq 21
access-list RESTRICT permit tcp host 192.168.5.11 host "ftp server ip" eq 20
access-list RESTRICT permit tcp host 192.168.5.11 host "ftp server ip" eq 21
access-list RESTRICT deny any host "ftp server ip" eq 20
access-list RESTRICT deny any host "ftp server ip" eq 21
access-list RESTRICT permit ip any any
Apply this inbound on the vlan 85 interface.
Jon
The ACLs which contain port 20 is overkill.
If you block command and control port (21),
there is no point in blocking data transfer
port (20).
Besides, the acl for port 20 is useless if the
user(s) use Active ftp.
David
David
Having port 20 in the access-list is hardly overkill to be honest. It's a layer 3 switch and a 7 line access-list should really be okay. i was trying to explain the concept of access-list order and as most people know ftp works on 2 ports i thought it should have both. It really won't do any harm.
Agreed on the active ftp but some people do use passive :-)
Jon
The point I am trying to make here is that
it is NOT necessary to do so. Imagine if you
do it in the Security lab, you will fail. Once
you block command and control port (tcp port
21) , it is irrelevant to block tcp port 20.
You will not get any hits in this ACL line.
David
CCIE Security
Okay well that's a bit of worry as Cisco doc for blocking ftp shows both ports being blocked
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml#denyftp
So follow their example and fail the lab !.
Point i was trying to make was that we aren't taking a lab. May not be necessary but won't do any harm either.
Anyway lets not get into an argument about it. The access-list will work whether port 20 is included or not and there will be no adverse effects whichever the original poster uses.
Jon
