Bloking Messengers
kthned
Level 3
Level 3
Hi All
I have a PIX 515E installed in my network having 150 PC. And I want to block MSN and yahoo for all users except for some particular user.Can u tell me how ca i block this thru PIX.
Thanks.
9 Replies 9
igorj
Enclosed are most of the ports these IMs are
using and basic ACL example.
For further info, please send what kind
of network scenario are you using, e.g. direct
access for clients and/or NAT for some/all of them
etc.
Ports used for YM and MSN IMs:
Yahoo Messenger
TCP 5000 5001 5100
UDP 5055
MSN
TCP 1863 6891 - 6901
UDP 1863 5190 6901
Basic ACL should look like:
access-list im_block deny tcp any any range 6891 6900
access-group im_block in interface EGRESS_IF
/Igor
MSN Messenger uses a varity of ports and protocols and is very adaptable. Is can ise Proxy settings, http or https and others. It thakes what ever is available !
MSN Messenger ports and IP's:
o 1863 (outbound TCP)
o 5060 for Session Initiation Protocol (SIP) (TCP)
o 1503 for Audio/Video, File Sharing and White Board (TCP)
o 6891-6900 for File Transfer (TCP)
o 3389 for Remote Assistance (TCP)
o UDP: 1503, 3389, 5004-65535
o IP Range 64.4.13.0/24
So on the PIX that would equate to:
example config:
access-list outbound deny tcp any any eq 1863
access-list outbound deny ip any 64.4.13.0 255.255.255.0
access-list outbound permit ip any any
access-group outbound in interface inside
sincerely
Patrick
Thanks Patrick for ur valuable reply, I hav a very simple scenario in which there is a Proxy server and a firewall , but i want to block MSN thru PIX. and i have to aloow MSN for some particular poool of IP address. say to 10.0.0.0/27 i.e for 30 users and block MSN and Yahoo for rest of the subnets.
Now wat i think , to block this
1. Make a for 10.0.0.0/27 to lets say 20.0.0.1
=> nat (inside) 1 10.0.0.0 255.255.255.224
=> global (outside) 1 20.0.0.1
2. Make a PAT for 10.0.0.0/8 to lets say 20.0.0.2
=> nat (inside) 2 10.0.0.0 255.0.0.0
=> global (outside) 2 20.0.0.2
3 Now Apply ACL like this
access-list outbound deny tcp host 20.0.0.2 any eq 1863
access-list outbound deny ip host 20.0.0.2 64.4.13.0 255.255.255.0
Will this block the MSN ,
I want also to block Yahoo messenger
Umair
Umair,
First at all the inside access-list will contain the inside IP Network not the outside one.
Hmm I an not sure if this nat global will work as it is overlapping in the 10.0.0.0 block. Might be better to choose a netblock that is completly diffrent or at least will not overlapp.
example config:
access-list outbound permit tcp PermitedIPBlock 255.x.y.z any eq 1863
access-list outbound permit ip PermitedIPBlock 255.x.y.z 64.4.13.0 255.255.255.0
If you want just to allow the proxy server to leave for http and https you could even be more specific.
Example:
access-list outbound permit tcp host ProxyInsideIP any eq 80
access-list outbound permit tcp host ProxyInsideIP any eq 443
access-list outbound permit tcp host ProxyInsideIP any eq 21
access-list outbound deny tcp any any eq 80
access-list outbound deny tcp any any eq 443
access-list outbound deny tcp any any eq 21
access-list outbound permit tcp Permited-Inside-IPBlock 255.x.y.z any eq 1863
access-list outbound permit ip Permited-Inside-IPBlock 255.x.y.z 64.4.13.0 255.255.255.0
.... Add there all other permited ports ....
sincerely
Patrick
Thanks for ur valuabe reply.
Yes Patrick u were right, but one thing to note that , In PIX if u do NATTING , the most specific IP address will translate first than less specific translation occurs.
regards
Umair
Umair,
don't forget to block Yahoo ! And you could use object groups to simplify the access-lists.
object-group service Messenger-UDP udp
port-object eq 5055
object-group service Messenger-TCP tcp
port-object eq 5000
port-object eq 5001
port-object eq 5100
port-object eq 1863
object-group service Proxy-TCP tcp
port-object eq 80
port-object eq 443
port-object eq 21
access-list outbound permit tcp host ProxyInsideIP any object-group Proxy-TCP
access-list outbound deny tcp any any object-group Proxy-TCP
access-list outbound permit tcp Permited-Inside-IPBlock 255.x.y.z any object-group Messenger-TCP
access-list outbound permit udp Permited-Inside-IPBlock 255.x.y.z any object-group Messenger-UDP
access-list outbound deny tcp any any object-group Messenger-TCP
access-list outbound deny udp any any object-group Messenger-UDP
sincerely
Patrick
Click on Rate this Post to help identify the most useful NetPro content.
Hello Patrick, I'm in a similar situation (block messenger and allow messenger for a little group), I tried to follow yours instruccions without luck...
could you help me?
thanks
If you have any IPS/IDS unit it would be much easier. do you have one?
No I don't have one
