Booting problem-- help needed
sachinraja
Level 9
Level 9
I booted a 7206 router and it booted in Rxboot mode. I wanted to boot from flash . so i gave the command config-register 0x2102 and rebooted the router. still i'm on rxboot mode. i gave sh version and it gave the config register setting as 0x2102. pl solve the issue.
regards,
rajagopal
mail me at rajagopal_s@satyam-infoway.com
ramesh_k_arora
better u change the config register to 0x102 then reboot if again it goes to Rxboot mode then switch off the router then again break then see the config register if it is the same that u have changed the config register then reboot. if prob comes pl reply
