cannot upgrade PIX515UR from 6.3 to 7.0 in monitor mode
nlariguet
issue # 1: Cannot upgrade PIX515UR from 6.3 to 7.0 in monitor mode
Monitor mode required because there's no enough memory to do it in normal mode.
I am experiencing the same problems as seen on another post but I can't getting working for me:
http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=n9v6ligfz1.SJ1B?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dda062b/1#selected_message
First and foremost, there's only one Intel SE7525GP2 workstation connected to the inside port on the firewall through a 3Com Office Connect Gigabit 8 switch (to enable auto-negotiation as advised) and no other computers/devices are present on the network and the firewall is currently without an outside connection (that is, until the OS can be upgraded). The workstation is running Windows 2003 and has the SolarNet TFTP Server running (which works perfectly on firewall normal mode).
To begin with, the firewall was reset to factory-default configuration with write erase and reload commands.
Address configuration (in monitor mode) is as follows [address] [mask] [gateway]:
firewall on [192.168.1.1] [] [192.168.1.1]
workstation on [192.168.1.3] [255.225.225.0] [192.168.1.1] (no DNS) (no Windows firewall) (the network adapter is an Intel Pro/1000 integrated on the motherboard)
If I ping from the firewall to server it's all OK.
If I ping from the server to the firewall only time-out's are reported.
If I the firewall address is changed to, say, 192.168.1.2 keeping the same 192.168.1.1 gateway all remains the same.
If no gateways are specified on both ends all remains the same.
I suppose that's why the TFTP Server report time-outs all the time and the firewall freezes (until I hit ESC) after issuing the TFTP command to initiate the image file transfer.
Please advise.
By the way: can PDM be uninstalled/removed/deleted from the firewall freeing space which will result on more memory thus allowing the OS upgrade to be done from normal mode ? Just curious about it.
issue # 2:
Let's suppose I get the OS (and ASDM) upgrade done.
How should I configure the outside interface to work with a cable modem with a dynamic IP assigned by my provider ?
I would like to keep the 192.168.1.x scheme from my internal network and has the outside assigned dynamically by the provider as usual.
maybe ip address outside dhcp ?
Thanks.
initial configuration provided on setup after clearing to factory-default:
The following configuration will be used:
Enable password: <my-password>
Clock (UTC): 01:33:00 Mar 19 2006
Inside IP address: 192.168.1.1
Inside network mask: 255.255.255.0
Host name: firewall
Domain name: LV-426
IP address of host running PIX Device Manager: 192.168.1.3
config terminal
pager lines 100
username Nacho password <my-password> privilege 15
show version
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 19-Mar-03 11:49 by morlee
firewall up 1 min 25 secs
Hardware: PIX-515, 128 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0004.2746.95ba, irq 11
1: ethernet1: address is 0004.2746.95bb, irq 10
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Interfaces: 6
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Serial Number: 481030818 (0x1cabf2a2)
Running Activation Key: xxxxx
Configuration last modified by at 06:28:16.000 UTC Thu Feb 7 2036
5 Replies 5
sebastan_bach
Level 4
Level 4
hi there i had the same issue. i got it. the problem is not with the pix it's with the windows 2003 . even i couldn't upgrade in the monitor mode.use a windows xp pc and things will work perfectly fine. it this solves ur issue then pls rate it. thank and bye
sebastan
I was out for the whole week. On Monday I will have access to an XP machine and check if it is Windows 2003 causing the trouble as you suggested.
By the way; I am upgrading from monitor mode because there's not enough flash memory to do it in normal mode, and I'm wondering if it's possible to make some space, for example, can the PDM 3 be removed ? It's obvious after I successfully upgrade OS to 7 I will place the newer ASDM. Another example: I noted flashfs command reports a 3 MB file holding "downgrade info". I won't need it, I don't see the point to have an older version, I want the last, can I delete it ?
Just wonder.
Thanks.
YOU WERE QUITE RIGHT: I was finally able to upgrade to 7.0.4 in monitor mode from an XP machine and not from a Windows 2003 Server one. It seems there's something on the monitor mode incompatible with Windows 2003 installations.
I cannot find the way or the option to rank your response, how do I ?
keyvansadeghi
I had a similar problem with tftp. It turned out my flash drive was faulty. Could delete files and copy the same files back to the drive (sometimes) but everything else just gave tftp errors.
RMA
