CDP bypass feature
nskarim
Hi folks,
I have been trying to browse cisco feature navigator for "CDP bypass" for 802.1x feature in order to have a clear picture of which IOS versions or platforms are supporting it, but i am unable to find it in the feature list ( at least with the name cdp bypass).
Does any one know if this is the correct feature name to look for? or anyone has a link to a document that give a better idea of IOS version supporting it or not?
I have been looking at just IOS-XE 3.3.0 which seems not to support it while IOS 3.7 does support it. In other document it is suppose to be a legacy feature so kind of strange there is support for 3.7 if not for 3.3.0
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-37xe-4500e.html?referring_site=RE&pos=2&page=http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_29983-01.html
thanks
/Karim
Collin Clark
It's a new feature in IOS XE 3.7.0E. In the Feature Navigator, it shows the hardware currently supported.
Hi Collin,
Thanks for your input. Still cannot see anywhere "CDP Bypass" mentioned. Unless another name is used on the feature navigator? attached is the result i have from the same query you posted.
Cheers
/karim
Not every feature is in FN and it can also takes a few months, for new features, to show up in FN.
