Cisco Air-ap1532e
Dear Cisco team,
i have cisco wireless controller 5800 series. i have 9 external Cisco AP 1532E i connected with POE Switch to AP but it is not showing in the my controller. can someone tell me how to configure that AP1532e and what is the initial step to configure.
Your reply will be highly appreciate
2 Accepted Solutions
Leo Laohoo
Is the MAC address of the AP entered into the MAC address table of the WLC?
Security AAA AP Policies, click Add.
Add the MAC address of the AP and then reboot the AP.
5 Replies 5
Leo Laohoo
When i go there in WLC there is couple of options i will add the MAC address of AP. then should i connect to serial cable with AP or i have to do some changing in AP?
Should I reboot the WLC or only AP?
Which Certificate I will select
attached image review kindly
