Bookmark
Subscribe
1387
Cisco Secure Access Control system TLS1.2 issue
gordonyang2
Does the Cisco Secure Access Control system 5.6 support a TLS 1.2?
What is the Cisco plans to support TLS 1.2 on Secure Access Control system 5.6 ?
Hello
i have seen that cisco ACS 5.8 is supporting TLS 1.2
(to support 802.1x on osx elcapitan and higher)
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-8/release/notes/acs_58_rn.html#pgfId-453813
Configuration guide :
ACS 5.8 after installing patch 4, enables TLS 1.2 for both browser access and runtime (AAA) access by default. For compatibility reasons, ACS allows you to enable and disable TLS 1.0 using the configuration available in System Administration > Configuration > Global System Options > Security Settings page.
i don't know the status for acs 5.6 ... but i doubt that there will be new features implemented in this version
regards
Guillaume
Please rate usefull posts.
Marvin Rhoads
As ACS 5.6 is end of sales (and almost end of maintenance), there will be no further enhancements to its functionality.
As Guillame correctly noted, ACS 5.8 does support TLS 1.2 as of Patch 4.
You could also migrate your ACS to ISE - it also supports TLS 1.2.
