Hi Guys,
I have a problem with encription.
I work with SAS Systems and a my customer have to trasfer data through the VPN network.
I noted from VPN client the files with length record over 27K the application don't go on.
With file with length record under 27K the application work properly.
Do you Know if there is a limit for the encription in VPN software ?
Regards Carmelo
