Command Authorization Sets
pallette
Level 3
Level 3
Is there a way to apply "Cat OS" commands to command authorization sets, instead of just IOS command on Cisco ACS 3.0 NT
skaragozian
Community Member
Yes,
Here is the link to configuring TACAC+ on Catalyst OS switches
http://www.cisco.com/warp/public/480/72.shtml
enjoy it.
Sarkis Karagozian
dan.richter
Community Member
'Not sure if this is what you're after. These will do what you seek; up to and including logging any commands entered into the switch afterward (recorded in the day's Administration report of ACS 😞
set tacacs server {addr.} primary
set tacacs server {addr. of secondary}
set tacacs key {secr. key}
set authentication login tacacs enable telnet primary
set authentication login local enable telnet
set authentication enable local enable telnet
set accounting commands enable all stop-only tacacs+
