Configuring a peer in PPTP
pferraz
Is it possible to specify the peer's IP (for security purposes) when configuring a PPTP tunnel terminating in a PIX Firewall ?
I've tried to do this with an access-list but the PIX doesn´t let me configure a rule that starts and terminates in the same interface....
Comments appreciated, thanks!
jfrahim
Level 5
Level 5
Hi there,
You cannot really restrict the PPTP user on the pix firewall itself. What you can do to achieve the same results is do define an ACL on the Interner router ( the router which acts as the default gateway on the pix) and apply that ACL on the interface connected to the outside interface of the pix
Hope that helps
Jazib
jfrahim
Level 5
Level 5
Hi there,
Hope that helps
Jazib
