configuring stateful cable base failover 515e 7.1(2)4
damrut5763
I have two 515e firewall with UR license can't get it to exchange info, the show I turnoff the secondary unit for now. failover shows:Failover On
Cable status: Other side powered off
Failover unit Primary
Failover LAN Interface: N/A - Serial-based failover enabled
Unit Poll frequency 5 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 1
Monitored Interfaces 6 of 250 maximum
failover replication http
Version: Ours 7.1(2)4, Mate Unknown
Last Failover at: 13:19:55 UTC Oct 19 2006
This host: Primary - Active
Active time: 10145 (sec)
Interface outside (12.184.170.2): Normal (Waiting)
Interface inside (10.1.1.2): Normal (Waiting)
Interface dmz (10.1.60.1): Normal (Waiting)
Interface intf3 (0.0.0.0): Link Down (Waiting)
Interface intf4 (0.0.0.0): Link Down (Waiting)
Interface failover (172.16.2.1): No Link (Waiting)
Other host: Secondary - Failed
Active time: 0 (sec)
Interface outside (12.184.170.3): Unknown (Waiting)
Interface inside (10.1.1.3): Unknown (Waiting)
Interface dmz (10.1.60.3): Unknown (Waiting)
Interface intf3 (0.0.0.0): Unknown (Waiting)
Interface intf4 (0.0.0.0): Unknown (Waiting)
Interface failover (172.16.2.2): Unknown (Waiting)
Stateful Failover Logical Update Statistics
Link : failover Ethernet5 (down)
Stateful Obj xmit xerr rcv rerr
General 0 0 0 0
sys cmd 0 0 0 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 0 0 0 0
Xlate_Timeout 0 0 0 0
VPN IKE upd 0 0 0 0
VPN IPSEC upd 0 0 0 0
VPN CTCP upd 0 0 0 0
VPN SDI upd 0 0 0 0
VPN DHCP upd 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 0 0
Xmit Q: 0 0 0
Have you tried booting the failover unit with the cable attached? It should by default pull the config from the active if it boots when an active is available across the cable.
Also, is it possible to get the output when the second unit is booted? That usually indicates if there is an issue.
Other possible things that come to mind:
Do you have the same OS on each?
Does the redundant have enough ram? I have seen people with 515s without 128MB try to configure failover. With 7.x, the redundantt requires 128MB.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_bulletin0900aecd8023c8d4.html
-Eric
Please remember to rate all helpful posts.
