Connecting 2 sites with same subnet
BRUNO WOLLMANN
Hi All,
I have two sites connected to the internet and I want to establish a VPN tunnel between these 2 sites. The main site will contain a PIX515 while the other site will contain a PIX506. Both sites use 10.x.x.x/255.0.0.0 addressing schemes however there are no duplicates across the 2 sites. My question is: is it possible to establish this connection without having to re-address one of these sites? My gut tells me that this is not possible (unless I use NAT) because traffic from 10.x.x.x hosts looking for another 10.x.x.x host would never be routed outside the source site.
thanks
Bruno
srg
I think you are correct. The only way to get the traffic across the vpn would be to change the subnet mask at both sites.
stevent
My friend i saw a cisco example explaining how to do this. I have never done it but i read the article. Now i cant remember where it is but i know i saw it.
Search cisco's website its there.
Hope you find it
c.peter
Proxy ARP should work, as it masquerades any remote host as being on the same wire. Please consult http://www.cisco.com/warp/customer/105/5.html and related docs.
Good luck!
I'm not sure Proxy ARP would work in this situation. The PIX doesn't support Proxy ARP anyway. You can do this, I also saw a document on it, but it would be an ugly NAT fiasco...
