09-20-2001 09:02 AM - edited 03-08-2019 08:44 PM
Hi All,
I have two sites connected to the internet and I want to establish a VPN tunnel between these 2 sites. The main site will contain a PIX515 while the other site will contain a PIX506. Both sites use 10.x.x.x/255.0.0.0 addressing schemes however there are no duplicates across the 2 sites. My question is: is it possible to establish this connection without having to re-address one of these sites? My gut tells me that this is not possible (unless I use NAT) because traffic from 10.x.x.x hosts looking for another 10.x.x.x host would never be routed outside the source site.
thanks
Bruno
09-20-2001 02:23 PM
I think you are correct. The only way to get the traffic across the vpn would be to change the subnet mask at both sites.
09-21-2001 04:28 PM
My friend i saw a cisco example explaining how to do this. I have never done it but i read the article. Now i cant remember where it is but i know i saw it.
Search cisco's website its there.
Hope you find it
09-28-2001 03:21 AM
Proxy ARP should work, as it masquerades any remote host as being on the same wire. Please consult http://www.cisco.com/warp/customer/105/5.html and related docs.
Good luck!
10-30-2001 02:16 PM
I'm not sure Proxy ARP would work in this situation. The PIX doesn't support Proxy ARP anyway. You can do this, I also saw a document on it, but it would be an ugly NAT fiasco...
