connection with Uf flags when server crash
r.spiandorello
Hi, pix or asa 7.0(4) version.
After a server crash event, a client send a fin packet and the connection moves to Uf flags state in the show conn.
After the server has been restored the connection is still present on the show conn and the only way to remove it is the clear local-host command on the pix.
It seems that the connection with Uf follow the timeout conn settings and there's no way to use the half-closed timeout to speed-up the conn automatic removing.
Could you help me ?
thank you in advance
smalkeric
Level 6
Level 6
The reason why you are seeing the flags with parameters is pix is trying to build up session table. Let me give you another example.
Inside: Outside Flags
SYN --> saA
<-- SYN + ACK A
ACK --> U
<-- Data UI
Data --> UIO
FIN --> Uf
<-- FIN + ACK UfFR
ACK --> UfFRr
I hope this answer your question.
