11-05-2004 11:29 AM - edited 03-09-2019 09:21 AM
I have pix 525 and 520 , and i am getting CRC errors on my DMZ interface. wants to clear the counter for that particular interface. wht is the command for that, and if i clear the interface is connectivity loss is there. i mean who ever is connected to that DMZ ,can we loss that connectivity for time being.
pls help me ....very urgent
Thanks & Regards,
Ciscobuddy
11-05-2004 11:49 AM
clear interface
Clear counters for the show interface command.
But you cannot define which interace. This will not reset any sessions just clear the counters.
Command reference:
sincerely
Patrick
11-05-2004 11:55 AM
Thanks for ur reply, it is ethernet2 that is my dmz.
pls suggest me if anything is there. i am on customer site.and pix is in production. so is there any problem to clear the counter. is production loss is there ?
pls advise me
Thanks & Regards,
Ciscobuddy
11-05-2004 12:17 PM
NO, I just tryed that on my PIX, I was downloading a large file and did a reset of the counters. There was no lost of the session.
do:
conf t
clear interface
YEAH, I have seen on your other post that you executed "clear xlate". This command has defenitly reset all sessions in your production. Take care with that command.
sincerely
Patrick
11-05-2004 12:43 PM
Hi Patrick,
Thanks again for ur reply, is this command clear all the interface on PIX. or i can clear only ethernet 2. sorry that i am asking you the silly questions, coz i never work on PIX.
pls advise me.
Thanks & Regards,
Ciscobuddy
11-05-2004 12:48 PM
Hi Patrick,
i hv cleared the interface. but still i am getting crc,input errors and ignored packet. can you pls advise me on this issue.
Thanks & Regards,
Ciscobuddy
11-05-2004 02:59 PM
There might be a host in difficulty to send packets, I have no idea if it is a NIC that is defective.
I will see what I can figure out about CRC. Basicly
the content of a packet has changed in transmition and the the PIX reject them, bad packets. This is a
Layer 2 problem not a routing issue.
In between figure out what is the source host that produces them. Put a packet sniffer into the DMZ.
If you have a Switch, check also the interface statistic on that switch that might help.
sincerely
Patrick
11-06-2004 09:30 AM
CRC Errors on pix interface.
Take a look at his links that might give a new direction to troubleshoot your problem.
http://support.intel.com/support/express/switches/sb/CS-014410.htm
http://www.computerhope.com/issues/ch000430.htm
http://support.3com.com/infodeli/tools/netmgt/tncsunix/product/091500/c11ploss.htm#20985
sincerely
Patrick
11-07-2004 02:15 AM
please check the following configuration on your pix interface and the connected interface on the other side:
- speed
- duplex
This settings should be the same. If your configuration looks like 'auto/auto', so configure fixed details, i.e. 100/full.
