I installed CSA on a server but unable to RDP after this.can some1 suggest how to make an exception for this ?
do a search it was answered before not to long ago
Abhishek,
As Jim mentioned you can simply do a search of the NetPro database on the right hands side of this page. Make sure to use the words CSA and RDP in the title. You will find this link:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc23a5f
Hope this helps.
Paul
It's also helpful to put something like that as the topic of your post.
"CSA 6.0 and RDP" makes it much easier to determine the thread.
Tom
Open the CSA MC console, and look at the log for the server. You can run the wizard to create an exception, and generate rules to apply it. You should be good.
