CSA Alarms not showing up in VMS
kbehymerisg
I have VMS with MC for CSA 4.5 installed. I can view reports under the "Management Center" -> "Security Agents 4.5" section. I cannot view any reports under the "Monitoring Center" -> "Security Monitor" -> "Reports" -> "CSA Alarms". It is like the CSA data only goes to "Management Center" -> "Security Agents 4.5" section. Anyone have any ideas how to get data to both areas?
gfullage
You're right, by default CSA alerts are only sent to the CSA MC, not into Secmon as well. You have to add the MC into SecMon just like you would with any other IDS or firewall device.
See the following link for what to do:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mon_sec/secmon21/sm21ug/ch03.htm#wp683090
gfullage
