we need to implement the following using CSA. Install CSA on user laptops running win2000/XP, and if the OS does not have the appropriate OS security patches, then the CSA should not allow the user to access the network. Is this possible?
Also, another question...is there an evaluation license for CSA to use?
Thanks a lot
