CSA
jpannorfi
Can someone tell me if CSA can prevent a workstation from applying bridging connections, if so is it a service or .exe that XP performs to enable bridging?
Thanks In Advance
tsteger1
Level 8
Level 8
CSA 5.2 can prevent traffic on a wireless adapter if the wired adapter is active.
I don't know about prohibiting more than one wired adapter.
If this is a problem in your organization, you may need to come at it from another angle by using a GPO that prohibits bridging.
Under Computer Policy> Computer Configuration > Administrative Templates > Network > Network Connections:
Enable "Prohibit installation and configuration of Network Bridge on your DNS domain network".
Tom
