Customize Cisco Trust Agent
cpubob
Is there a way to customize the CTA agent? Specifically, the default network config is named "Cisco Corporate". When you are prompted for creditials, is asks for info for the network Cisco Corporate. Even when I create a custom deployment config, it still says Cisco Corporate. I've tried editing the files but that only causes the agent to crash after a reboot. What am I missing? There is something obvious that I just am overlooking. Thanks in advance.
-Rob
abz
Rob,
currently there is no way to change this field. I have talked to Cisco and they are working on a way to resolve this. It is something that they know about and hopefully will have it fixed soon. for the time being you will unfortunately just have to deal with it. If you upgrade to the full verison of Meetinghouse you will be able to change that field.
Adam
