10-28-2004 03:11 PM - edited 03-09-2019 09:15 AM
I'm tring to configure DDNS features.
How can I insert this command :
<A HREF="javascript:newWin('http://USERNAME:PASSWORD@members.dyndns.org/nic/update?system=dyndns&hostname')">http://USERNAME:PASSWORD@members.dyndns.org/nic/update?system=dyndns&hostname</A>=<h>&myip=<a>
It's not permit to insert "?" (the question mark) in the configure mode. Is there any way solve this problem.
10-28-2004 06:36 PM
Not sure what you're trying to do exactly, but if you're trying to add a ? into the IOS router config, then press CTRL-V before the question mark, IOS will then allow you to enter the question mark as part of the command line.
10-29-2004 01:57 PM
I'm trying to test the new cisco feature Dynamic DNS in order to have a fix DNS name entry with an IP address negotiated.
Thank for your help.... now everythings is working well.
