DDNS Update over https (ssl cert problem)
sf_online
Community Member
I tryed to setup that my c836 router use https to send host updates crypted to members.dyndns.org but it will not work.
I used the following howto:
http://www.dyndns.com/support/kb/configuring_cisco_https.html
and selected the Root 4 - Equifax Secure eBusiness CA-1 (Base-64 encoded X.509) to copy / paste from http://www.geotrust.com/resources/root-certificates/ to my router.
show debugging
Dynamic DNS debugging is on
SSL Subsystem:
SSL Handshake Message debugging is on
SSL Error debugging is on
SSL Event debugging is on
That give me the following output:
File ../crypto/ssl/src/sslhdshk.c; Line 212 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/sslhdshk.c; Line 257 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/sslhdshk.c; Line 113 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 369 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 270 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 250 # Error -1006 [SSLPKICertValidationErr]
00:46:24: DYNDNSUPD: Adding DNS mapping for xxx.homedns.org <=> x.x.x.x
00:46:24: HTTPDNS: Update add called for xxx.homedns.org <=> x.x.x.x
00:46:24: HTTPDNSUPD: Session ID = 0xB
00:46:24: HTTPDNSUPD: URL = 'https://user:[email protected]/nic/update?hostname=xx.homedns.org'
00:46:24: HTTPDNSUPD: Sending request
00:46:24: SSL Client Initialization Successful.
00:46:24: SSL: client hello encoded successfully.
00:46:24: SSL: write record: type: ssl handshake.
01 00 00 2F 03 00 4A DE 6A A6 3F 1E B1 BE A0 98
65 4A 76 B9 92 86 47 DB 96 E6 F3 F2 37 D4 8C 80
0E 2A 82 BF 84 48 00 00 08 00 04 00 05 00 0A 00
09 01 00
00:46:24: SSL: read record: type: ssl handshake.
02 00 00 46 03 00 4A DE 6A A6 6B F3 33 FB 80 FD
13 9D 35 01 CB C3 B5 AB 32 6C DB C3 6A 1E 51 6E
F0 17 E4 93 A8 FC 20 21 E4 27 39 C6 C0 4D 00 B9
AE FB 6D 04 91 4B BD 86 20 FD 39 C1 9E 01 9A 71
E5 72 78 81 A1 3A 19 00 04 00
00:46:24: SSL: process server_hello
00:46:24: SSL: server hello processed successfully.
5 Replies 5
sf_online
Community Member
0B 00 03 46 00 03 43 00 03 40 30 82 03 3C 30 82
02 A5 A0 03 02 01 02 02 03 0A 8E A2 30 0D 06 09
2A 86 48 86 F7 0D 01 01 05 05 00 30 4E 31 0B 30
09 06 03 55 04 06 13 02 55 53 31 10 30 0E 06 03
55 04 0A 13 07 45 71 75 69 66 61 78 31 2D 30 2B
06 03 55 04 0B 13 24 45 71 75 69 66 61 78 20 53
65 63 75 72 65 20 43 65 72 74 69 66 69 63 61 74
65 20 41 75 74 68 6F 72 69 74 79 30 1E 17 0D 30
39 30 31 32 39 31 39 31 30 31 31 5A 17 0D 31 30
30 33 30 31 31 39 31 30 31 31 5A 30 81 C6 31 0B
30 09 06 03 55 04 06 13 02 55 53 31 1B 30 19 06
03 55 04 0A 13 12 6D 65 6D 62 65 72 73 2E 64 79
6E 64 6E 73 2E 6F 72 67 31 11 30 0F 06 03 55 04
0B 13 08 38 30 34 30 31 33 36 37 31 31 30 2F 06
03 55 04 0B 13 28 53 65 65 20 77 77 77 2E 67 65
6F 74 72 75 73 74 2E 63 6F 6D 2F 72 65 73 6F 75
72 63 65 73 2F 63 70 73 20 28 63 29 30 39 31 37
30 35 06 03 55 04 0B 13 2E 44 6F 6D 61 69 6E 20
43 6F 6E 74 72 6F 6C 20 56 61 6C 69 64 61 74 65
64 20 2D 20 51 75 69 63 6B 53 53 4C 20 50 72 65
6D 69 75 6D 28 52 29 31 1B 30 19 06 03 55 04 03
13 12 6D 65 6D 62 65 72 73 2E 64 79 6E 64 6E 73
2E 6F 72 67 30 81 9F 30 0D 06 09 2A 86 48 86 F7
0D 01 01 01 05 00 03 81 8D 00 30 81 89 02 81 81
00 98 ED F7 8B AE A9 1E AC DC 22 84 61 82 09 43
72 2D 04 12 E5 1A 16 99 EF 72 7B 7A 1C 1F E0 86
EA 4D 64 D6 D2 74 9C 44 A3 9D 36 BF C0 F8 C1 3F
FC 30 D8 E9 90 FD 20 D8 93 2F CB D5 37 29 BF F7
E7 7B C7 50 99 D9 95 F9 95 72 DA ED DD 1F 7D 40
95 D3 7A D9 0D 98 F6 09 E0 7F 65 2E 23 53 86 A8
57 4E D7 16 B4 CF E5 D7 D8 6A 3E EB 4D CB 29 67
E9 10 A3 3C 05 88 E7 5D B9 F7 C3 5E FB A5 05 4C
4F 02 03 01 00 01 A3 81 AE 30 81 AB 30 0E 06 03
55 1D 0F 01 01 FF 04 04 03 02 04 F0 30 1D 06 03
55 1D 0E 04 16 04 14 72 6A EB 0D BB C8 EB BE BE
2B B6 A5 59 DD D4 D4 31 3D 80 15 30 3A 06 03 55
1D 1F 04 33 30 31 30 2F A0 2D A0 2B 86 29 68 74
74 70 3A 2F 2F 63 72 6C 2E 67 65 6F 74 72 75 73
74 2E 63 6F 6D 2F 63 72 6C 73 2F 73 65 63 75 72
65 63 61 2E 63 72 6C 30 1F 06 03 55 1D 23 04 18
30 16 80 14 48 E6 68 F9 2B D2 B2 95 D7 47 D8 23
20 10 4F 33 98 90 9F D4 30 1D 06 03 55 1D 25 04
16 30 14 06 08 2B 06 01 05 05 07 03 01 06 08 2B
06 01 05 05 07 03 02 30 0D 06 09 2A 86 48 86 F7
0D 01 01 05 05 00 03 81 81 00 37 6B 1E 31 A8 F1
47 F8 25 D9 D8 8D C2 ED E6 F5 EC 53 48 71 E1 40
6C B6 6E B0 67 88 4E 8B 3B 46 0E 3C 0D AB A8 3A
09 DC B0 50 31 FF 6D B8 A8 E1 C5 42 D5 52 0E DF
AC E5 3A C6 24 12 D8 E6 3F CF F5 05 6C 35 38 C6
9D B6 F2 15 18 CA 8D BF 46 01 8C 33 13 36 C1 BE
FF 66 39 2C E9 91 FD C6 B0 A2 B0 B0 74 27 56 61
0E E5 29 13 30 02 FD A3 DA 8E A0 D1 13 ED 14 13
AD 1F D8 10 D7 F5 1D E4 30 6A
00:46:24: SSL: process certificate
00:46:24: CRYPTO_SSL crypto_ssl_nonblocking_checkcert: Cert validation failed within PKI!
00:46:24: CRYPTO_SSL crypto_ssl_nonblocking_checkcert: The returned error code from PKI is -1006!
00:46:24: SSL: write record: type: ssl alter 02 00
00:46:24: HTTPDNSUPD: Call returned Request Aborted for update xx.homedns.org <=> x.x.x.x
00:46:24: DYNDNSUPD: Another update completed (outstanding=0, total=0)
00:46:24: HTTPDNSUPD: Clearing all session 11 info
can anyone help me please to get this fixed? i am not sure where i can start to get this working^^
Thanks!
Is nobody here who can help please? ^^
I confirm similar behavior...need to be able to configure the SSL client to force accept:
004363: Jan 26 03:29:41.876 EST5EDT: 0:error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed:../VIEW_ROOT/cisco.comp/pki_ssl/src/openssl/dist/ssl/s3_clnt.c:1048:
Here is a copy my blog post on the topic...
I got aroud the issue with HTTPs in the DDNS client by manually creating a trustpoit and importing the certificate of the signing cert used on the HTTPs/Apache service on my domain provider (PairNIC)'s web service
Here is a simple guide of how to integrate your Cisco IOS router platform with your PairNIC-managed domain name.
This  is a useful if you are buying commodity broadband connectivity from a  hetergenous selection of regional service providers that use DHCP on a  bridged ethernet WAN (Verizon FIOS, Comcast broadband, Consolidated  Communications metro ethernet)
As you can see below,  PairNIC makes-available a REST-style HTTP WebServices URL that you can  pass simple GET-style calls to with the HTTP client in Cisco IOS  routers.
NOTE: The password field below is not your  PairNIC password, but instead, a dynamic key that is generated when you  turn on Custom DNS for your domain and enable dynamic updates
NOTE: PairNIC domains are supported.  Pair.com-managed-domains are not supported.
This works out, because you likely want to have a separate domain name for WAN DDNS updates
NOTE:  You do not need to have an A-record in place already, despite the  ambiguously named '/update' method-call below, it will actually create  records on-demand.
NOTE: I'm not sure if there is an erase/delete/destroy/remove function call -- Waiting to hear back from Pair
br00>sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
br00# conf t
ip ddns update method PairNIC
HTTP
   add  https://[PairNIC-Customer-Name]:[Domain-DDNS-Key-from-PairNIC.com]@dynamic.pairnic.com/nic/update?hostname=&myip=
interface GigabitEthernet0/1
description WAN Facing ISP
ip dhcp client client-id ascii hostname.domain.tld
! These two are likely to be ignored by your ISP's DHCP Server
! But useful to demonstrate how you could have an Cisco IOS
! DHCP server dispatch requests from Cisco IOS DHCP Clients
! in a enterprise network
ip dhcp client hostname hostname.domain.tld
ip dhcp client update dns server both
! This
ip ddns update hostname hostname.domain.tld
ip ddns update PairNIC host hostname.domain.tld
ip address dhcp
ip flow ingress
ip nat outside
ip inspect CBAC-IN-OUT out
ip virtual-reassembly in
ip access-class BogonOutside in
duplex auto
speed auto
ipv6 enable
no cdp enable
crypto map MyMap-DYMMAP
Turn on DDNS debugging to see the DDNS HTTP client functional steps:
router# debug ip ddns update
Force a release and renewal on your WAN interface (or VLAN)
br00#release dhcp gi0/1
br00#renew dhcp gi0/1
Turn on debugging to see the DDNS HTTP Client functional:
004017: Jan 26 03:09:06.110 EST5EDT: HTTPDNS: Update add called for br00.facilityCode.company.tld <=> 209.166.123.123
004018: Jan 26 03:09:06.110 EST5EDT: HTTPDNSUPD: Session ID = 0xE
004019:  Jan 26 03:09:06.110 EST5EDT: HTTPDNSUPD: URL =  'https://FOO:[email protected]/nic/update?hostname=br00.facilityCode.company.tld&myip=209.166.123.123[email protected]/nic/update?hostname=br00.facilityCode.company.tld&myip=209.166.123.123'
NOTE:  At this point, we see the HTTP CURL/WGET client in Cisco IOS doing what  it _should_ do -- however, it will fail because the SSL Library in IOS  (OpenSSL) doesnt ship with a proper set of trusted root CA Certificates
To  fix(*) this, we simply import and explicitly-trust the certificate that  signed the SSL cert used on PairNIC's cert for 'dynamic.pairnic.com'
(*) Its more of a cheap hack.  Cisco can fix by shipping a CA Cert Chain with OCSP/CRL enabled by default.
br00# conf t
br00(conf)# no crypto pki trustpoint CA-AddTrust-UserTrust
br00(conf)# crypto pki  trustpoint CA-AddTrust-UserTrust
enrollment terminal pem
revocation-check none
crl optional
br00(ca-trustpoint)#crypto pki authenticate CA-AddTrust-UserTrust
Enter the base 64 encoded CA certificate.
End with a blank line or the word "quit" on a line by itself
   [PEM Certificate here -- see below for openssl(1) command to extract on UNIX]
Trustpoint 'CA-AddTrust-UserTrust' is a subordinate CA and holds a non self signed cert
Certificate has the following attributes:
       Fingerprint MD5: F2CB531D 39AA97FF 39900B79 1319ABD4
      Fingerprint SHA1: 10189D78 180A33A9 DF7219F0 6D15FC86 5C9A6160
% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
% Certificate successfully imported
And here is functional real-world example of this working:
004675:  Jan 26 03:51:25.780 EST5EDT: DYNDNSUPD: Adding DNS mapping for  test.probikesllc.biz <=> 192.168.15.167 server 216.151.95.152
004676: Jan 26 03:51:25.780 EST5EDT: HTTPDNS: Update add called for test.probikesllc.biz <=> 192.168.15.167
004677: Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: Session ID = 0x11
004678:  Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: URL =  'https://[FOO]:[BAR]@dynamic.pairnic.com/nic/update?hostname=test.probikesllc.biz&myip=192.168.15.167'
004679: Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: Sending request
004680: Jan 26 03:51:26.652 EST5EDT: opssl_SetPKIInfo entry
004681: Jan 26 03:51:26.652 EST5EDT: opssl_SetPKIInfo done.
004682: Jan 26 03:51:27.140 EST5EDT: opssl_SetPKIInfo entry
004683: Jan 26 03:51:27.144 EST5EDT: opssl_SetPKIInfo done.
004684: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: Response for update test.probikesllc.biz <=> 192.168.15.167
004685: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: DATA START
good 192.168.15.167 <----!! HTTP 2xx Code returns single line
004686: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
004687:  Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: Call returned SUCCESS, update  of test.probikesllc.biz <=> 192.168.15.167 succeeded
004688: Jan 26 03:51:28.532 EST5EDT: DYNDNSUPD: Another update completed (outstanding=0, total=0)
004689: Jan 26 03:51:28.536 EST5EDT: HTTPDNSUPD: Clearing all session 17 info
004690: Jan 26 03:51:29.544 EST5EDT: DHCP: Client socket is closed
004691: Jan 26 03:51:33.464 EST5EDT: DHCPD: checking for expired leases.
$ openssl s_client -showcerts -host dynamic.pairnic.com -port 443
-----BEGIN CERTIFICATE-----
MIIE/zCCA+egAwIBAgIQZGN9fqrQa65AVz1hK2fc9jANBgkqhkiG9w0BAQUFADBv
MQswCQYDVQQGEwJTRTEUMBIGA1UEChMLQWRkVHJ1c3QgQUIxJjAkBgNVBAsTHUFk
ZFRydXN0IEV4dGVybmFsIFRUUCBOZXR3b3JrMSIwIAYDVQQDExlBZGRUcnVzdCBF
eHRlcm5hbCBDQSBSb290MB4XDTEwMDQxNjAwMDAwMFoXDTIwMDUzMDEwNDgzOFow
gYwxCzAJBgNVBAYTAlVTMRMwEQYDVQQIEwpOZXcgSmVyc2V5MRQwEgYDVQQHEwtK
ZXJzZXkgQ2l0eTEeMBwGA1UEChMVVGhlIFVTRVJUUlVTVCBOZXR3b3JrMTIwMAYD
VQQDEylVU0VSVHJ1c3QgSGlnaC1Bc3N1cmFuY2UgU2VjdXJlIFNlcnZlciBDQTCC
ASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAK6MzZglkPqv+uBYSaD8PBfo
WS0TmAuGqzjXcfBzD9b6rlV6yMRKgWyC8OO4TDTnwPWwxiJZZTXHg5G2/eXKzAOB
MMlfKsqmz04U8BefeQVRwLp2pzEMpFiGC/Xcz1RXZpVtS2FXkeGChKOTVy1PzIpG
7Ng5rmwDbacQ+gENZm08qoefd7WYJtGAq2/ddf2IHPg6xSmtnYU7pTluzjAs9QsA
ACsX6zD18H0ItznMqL0FwZIkk9ZnyhWjc5pmo8RyKBslxupC0SGIUffkYYt0zDct
vg0bUmLp2Ody9+isYcCydt8M92Gzkb4hfdBKlaEYiXjD5Da3wIAmUAzNFvYZWlUC
AwEAAaOCAXcwggFzMB8GA1UdIwQYMBaAFK29mHo0tCb3+sQmVO8DveAky1QaMB0G
A1UdDgQWBBRT6FMyCZPaxo7B7Ut2No/A8uZqdDAOBgNVHQ8BAf8EBAMCAQYwEgYD
VR0TAQH/BAgwBgEB/wIBADARBgNVHSAECjAIMAYGBFUdIAAwRAYDVR0fBD0wOzA5
oDegNYYzaHR0cDovL2NybC51c2VydHJ1c3QuY29tL0FkZFRydXN0RXh0ZXJuYWxD
QVJvb3QuY3JsMIGzBggrBgEFBQcBAQSBpjCBozA/BggrBgEFBQcwAoYzaHR0cDov
L2NydC51c2VydHJ1c3QuY29tL0FkZFRydXN0RXh0ZXJuYWxDQVJvb3QucDdjMDkG
CCsGAQUFBzAChi1odHRwOi8vY3J0LnVzZXJ0cnVzdC5jb20vQWRkVHJ1c3RVVE5T
R0NDQS5jcnQwJQYIKwYBBQUHMAGGGWh0dHA6Ly9vY3NwLnVzZXJ0cnVzdC5jb20w
DQYJKoZIhvcNAQEFBQADggEBABrrxypN7zC2awXPu3GFXvAI4CLEOx03RKf3vsZq
CaGZMfVfID79oJosLqulp1/3A/g6O2z5chBoP3iGjGuBQokfs9vbdyf8BWRMJhlW
pHsFGU7hGm4jKQ4/xuXn9tl3hUZRfdUKEYZgwNpxK3BU4TQ+cpvvgW8FoeXo9L1J
oDJFXTlItp8yVEUDwtCOxX16+U3kDFCADm/HUs19nQHtlqMkh94umU0KTtJFRHgw
qs6xdRhimRjOKLeQBRMcNxaCd0iNa6dMHUtOq9eM1V0i699L3+5VTPVK5tDbM3eF
fhkMMTS4Zabcp7rnCcJUXjpzvBpczMGWTWHh3aaBcn7dADk=
-----END CERTIFICATE-----
Which certificate did you import? The root CA, subordinate CA, or the certificate that was actually issued to the HTTPS site?
