06-03-2002 10:44 PM - edited 03-08-2019 10:50 PM
I have strange problem with vpn client 3.5.2 when connecting to PIX 6.0
when I use pre-share auth I can use DES encription. When I configure client to use MS certificate DES policy is not sent via IKE but only 3DES and PIX does not find a match. MS guys say that there certificate services have nothing to do with it and that client certificate does not contain any info about encryption level. Is there any way to solve it rather then updating PIX to use 3DES. DES would be more then enough for me.
06-04-2002 06:08 AM
Please check whether you have any IKE proposals defined for DES/MD5 or SHA / Digital Certificate combination in PIX.
If you post the relevant configuration, it would be easy to provide a correct response.
06-05-2002 04:49 AM
Sure I have. Config is here. Could it be because of "ca identity abcd 192.168.1.5:/certsrv/mscep/mscep.dll " is pointing to local address? I think it is needed only to PIX not to vpn client. IKE is suddenly interupted during negotiation. Detailed debug info can be viewed at
I can't post it right here because it is too big.
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dymap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dymap
crypto map mymap client configuration address initiate
crypto map mymap interface outside
isakmp enable outside
isakmp policy 10 authentication rsa-sig
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3 address-pool ippool
vpngroup vpn3 dns-server 192.168.1.5
vpngroup vpn3 default-domain generaldata.ru
vpngroup vpn3 split-tunnel aclipsec
vpngroup vpn3 idle-time 1800
vpngroup vpn3 password ********
ca configure abcd ra 1 20 crloptional
06-10-2002 04:58 AM
I also had the problem. It seems, that when you use Digital Certificates
w/ your client, the client do not offer any DES proposal. On my own, I only used
the client w/ pre-shared and solved (my ) the problem.
But, as you now, it does not scale well.
