Detailed logging
tclark2
I have a 3015 Concentrator. I have several LAN-to-LAN connections. Is there any way that I can enable more detailed logging on just one of the connections? I want to be able to see what traffic is being allowed/blocked by the filter that I have in place for one connection. Does it have to be enabled for all the connections? What logging option would give me that much detail? Thanks.
Richard Burts
You can change the level of detail of the logs by configuring events and classes. But I am not aware of any way on the concentrator to apply these levels to only a single connection.
Rick
Rick
