DMVPN missing features
warmteservice
Is there a way to set the tunnel transmit and receive bandwidth the command "tunnel bandwidth receive" is not in the command list (maybe wrong IOS currently running c1841-advsecurityk9-mz.123-8.T11.bin) or is this something in the platform we are using (C1841 for the test env). I cannot find anything on netpro. The current problem is that the speed is not exceeding 8000kbps width a 100 mbit line available.
Kind regards
vkapoor5
Level 5
Level 5
12.3(7)T This command was introduced.
tunnel bandwidth receive - Specifies the bandwidth to be used to receive packets through the tunnel.
Note This keyword is no longer used and will be removed in future releases.
