Does ASA5520 suports WebVPN from a PDA?
jean.l.pierre
Hi!
I'm trying to make a customer to access his email server (POP3) trough WebVPN on his QTEK PDA. I read that port-forwarding is not suported. Is this true?
JP
fmeetz
Level 4
Level 4
WEBVPN Port Forwarding is not supported in ASA 5520, whereas you can configure POP3 which operates independent of the WebVPN
you can try these
pop3s
enable outside
server 192.168.x.x
default-group-policy xxxxx
smtps
enable outside
port 998
server 192.168.x.x
default-group-policy xxxxxxx
Hi!
WebVPN is supported in all ASA55xx as you can see in the link below or in the equipment datasheet.
The configuration you sugest is to be made in the ASA?
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_book09186a008054c15c.html
Thanks for your help.
JP
