Does VPNClient3 to PIX506 v6.0(1) through 2501 work?
mburnford
Reading these messages it seems that there are things that don't work yet. Is it possible for a VPNClient3 to get to a network protected with a PIX506 v6.0(1), with a Cisco2501 router between the PIX and the ISP's Kilostream line?
Protocols 50 and 51 and udp port 500 are open on the router, but it still won't connect. If this combination won't work I'll stop trying to make it work! What do I need instead?
Michael
bsharma
Are you or ISP running NAT /PAT on the router. If this so then you need to enable "connection thru NAT " option under the VPN client properties.
Thx
The 'connection thru NAT' option you're talking about doesn't work with connections terminated on the PIX, only on a concentrator.
