Double NAT example
0sgruttadauria
I need to set up an IPSEC tunnel between two devices.
The networks on each side of the tunnel use the same address space (two different companies though).
Anyone have a good configuration example on how you would accomplish this with NAT.
e-Mail to steveg@rochester.rr.com or post here
Thanks.
smalkeric
Level 6
Level 6
What two devices? Cisco routers?
ddawson
I think this ought to do what you want (see below). I started with working router configs and cut out the extraneous stuff. Both the routers have local LAN networks of 192.168.0.0/24 and are set to use 10.1.1.0/24 and 10.2.2.0/24, respectively, with NAT. As long as your access-list in the crypto map refers to the 10.x.x.0 addresses, it all ought to work.
Good luck!
----- Router 1 -----
version 12.0
hostname ROUTER_1
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key CISCO1234 address 2.2.2.2
crypto ipsec transform-set MYSET esp-3des esp-sha-hmac
crypto map CRYMAP 10 ipsec-isakmp
set peer 2.2.2.2
set transform-set MYSET
match address 101
interface FastEthernet0
description LAN interface
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Serial0
description WAN interface
ip address 1.1.1.1 255.255.255.252
ip nat outside
crypto map CRYMAP
ip nat inside source static network 192.168.0.0 10.1.1.0 /24 no-alias
access-list 101 permit ip 10.1.1.0 0.0.0.255 10.2.2.0 0.0.0.255
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
end
----- Router 2 -----
version 12.0
hostname ROUTER_2
encr 3des
crypto isakmp key CISCO1234 address 1.1.1.1
set peer 1.1.1.1
match address 101
ip nat inside
interface Serial0
ip address 2.2.2.2 255.255.255.252
ip nat outside
crypto map CRYMAP
ip nat inside source static network 192.168.0.0 10.2.2.0 /24 no-alias
access-list 101 permit ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
ip classless
end
