DSL for 3600
abbas.ali
Does anyone know if 3600 series router supports DSL Technologies. I will be setting up a VPN Site to Site between the 6 branches I have with 3600 series router and the Central site has PIX 515. I would rather use DSL instead of Fractional T1 since DSL can provide the same speed at the cheaper price.
gfullage
You should be able to get a WIC-1ADSL for the 3600, the SW/HW compatibility matrix (http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi) says it's available. Looks like you'd need to run 12.2(4)T or higher to support it though.
Your Account Manager or reseller is probably a better person to speak to, but it should be available.
