09-06-2006
05:23 PM
- last edited on
03-25-2019
05:08 PM
by
ciscomoderator
Hi All,
I am trying to configure a dynamic NAT for a subnet. The subnet I have is 10.32.28.0/21 and I would like to xlate it to x.x.98.0/23.
Do I need to use policy NAT for this?
thanks
09-06-2006 05:51 PM
Hi .. You should be able to configure it as below
nat (inside) 1 10.32.28.0 255.255.248.0
global (outside) 1 x.x.98.0 netmask 255.255.254.0
Be aware that /21 mask on your case applies to network 10.32.24.0 ( range 10.32.24.1- 10.32.31.254)
I hope it helps .. please rate it if it does !!!
09-06-2006 07:35 PM
I tried entering
FWSM1(config)# nat (inside) 1 10.32.28.0 255.255.248.0
and I get this message.
WARNING: IP address <10.32.28.0> and netmask <255.255.248.0> inconsistent
So, I entered it as a
FWSM1(config)# nat (inside) 1 10.32.28.0 255.255.252.0
FWSM1(config)# nat (inside) 1 10.32.32.0 255.255.252.0
and I did not get any warning. NAT seems to be working though.
09-06-2006 09:16 PM
Hi .. yes that is because the 10.32.28.0 /21 falls in to the network address 10.32.24.0 / 21.
09-07-2006 04:00 AM
Oops! that is correct. I do not know what I was thinking. Having two /22 works better.
Thank you so much!
