echo and echo reply
aksher
what is the difference between echo and echo reply in icmp permit any echo inside
and vice versa..
5 Replies 5
Collin Clark
One is a request, the other is the reply.
so does the request send only a request and reply both request and reply?
ICMP echo-request is generated by the device from which the PING is originated. ICMP echo-reply is sent by the target device to the requesting device stating that it received the echo-request.
Sundar
my ques here is if yoou have only one either echo request or echo reply what will be the effect as given in command
icmp permit any echo-request inside
or
icmp permit any echo-reply inside
a. icmp permit any echo-request inside
- can send ping request to inside interface, but sender will not get reply.
b. icmp permit any echo-reply inside
- can get reply when pinging inside interface
To control ping request directed to your firewall interfaces, allow only specific ICMP type, i.e, allow only trusted IP/host to ping.
Carefully when allow ping to your outside interface from any internet/external host, esp to avoid ping/icmp attack.
http://www.cisco.com/en/US/customer/products/ps6120/products_command_reference_chapter09186a008063f9fd.html#wp1629224
http://www.rhyshaden.com/icmp.htm
http://groups.google.com.my/group/comp.security.firewalls/browse_thread/thread/2e4d1cf5ce99e9cf/27da7044c784e60e?lnk=st&q=why+ICMP+to+allow+request+reply&rnum=3&hl=en#27da7044c784e60e
Cheers!
AK
