EIGRP flaps after CoPP is applied
katerina86
R1#show ip access-lists 130
Extended IP access list 130
10 permit eigrp any host 224.0.0.10 (349 matches)
20 permit eigrp host 224.0.0.10 any
30 permit eigrp any any (280 matches)
40 permit ip host 172.16.1.1 any
50 permit ip host 192.168.1.1 any
60 permit ip 10.1.0.0 0.0.255.255 any (10 matches)
70 permit ip any any
class-map match-all CoPP-CRITICAL
 match access-group 130
class-map match-all CoPP-NORMAL
 match access-group 122
class-map match-all CoPP-IMPORTANT
 match access-group 121
policy-map CoPP
 class CoPP-CRITICAL
  police 1000000 50000 50000 conform-action transmit  exceed-action transmit
 class CoPP-IMPORTANT
  police 1000000 20000 20000 conform-action transmit  exceed-action drop
 class CoPP-NORMAL
  police 64000 6400 64000 conform-action transmit  exceed-action drop
 class class-default
  police 8000 1500 1500 conform-action drop  exceed-action drop
control-plane
 service-policy input CoPP
After I applied the service policy CoPP EIGRP flaps every min:
R1#
*Mar 10 10:52:05.100: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.13.2 (Ethernet1/1) is down: retry limit exceeded
R1#
*Mar 10 10:52:08.063: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.13.2 (Ethernet1/1) is up: new adjacency
R1#
*Mar 10 10:52:13.235: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.12.2 (Ethernet1/0) is down: retry limit exceeded
R1#
*Mar 10 10:52:18.030: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.12.2 (Ethernet1/0) is up: new adjacency
R1#
*Mar 10 10:53:27.663: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.13.2 (Ethernet1/1) is down: retry limit exceeded
R1#
R2#debug ip eigrp neighbor
R2#
*Mar 10 10:42:34.214: EIGRP: Retransmission retry limit exceeded
*Mar 10 10:42:34.222: EIGRP: Holdtime expired
*Mar 10 10:42:34.222: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.12.1 (Ethernet1/0) is down: retry limit exceeded
R2#
*Mar 10 10:42:34.222: Going down: Peer 10.1.12.1 total=0 stub 0, iidb-stub=0 iid-all=0
*Mar 10 10:42:34.222: EIGRP: Handle deallocation failure [0]
*Mar 10 10:42:34.224: EIGRP: Neighbor 10.1.12.1 went down on Ethernet1/0
R2#
*Mar 10 10:42:37.968: EIGRP: New peer 10.1.12.1
R2#
*Mar 10 10:42:37.968: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 10.1.12.1 (Ethernet1/0) is up: new adjacency
*Mar 10 10:42:38.197: EIGRP: Retransmission retry limit exceeded
*Mar 10 10:42:38.202: EIGRP: Holdtime expired
Am I missing anything on ACL 130?
22 Replies 22
No changes.
Extended IP access list 121
10 permit tcp 10.1.0.0 0.0.255.255 any eq 22
Extended IP access list 122
10 permit udp 10.1.0.0 0.0.255.255 any range 33434 33464
10 permit eigrp any any (239 matches)
Extended IP access list 131
10 permit ip 10.1.0.0 0.0.255.255 any
Extended IP access list 132
Extended IP access list 133
10 permit eigrp host 224.0.0.10 any
R1#show class-map
Class Map match-any CoPP-CRITICAL (id 1)
Match access-group 130
Match access-group 131
Match access-group 132
Match access-group 133
Class Map match-all CoPP-NORMAL (id 2)
Match access-group 122
Class Map match-any class-default (id 0)
Match any
Class Map match-all CoPP-IMPORTANT (id 3)
Match access-group 121
R1#show policy-map control-plane input
Control Plane
Service-policy input: CoPP
Class-map: CoPP-CRITICAL (match-any)
1908 packets, 131969 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: access-group 130
315 packets, 21668 bytes
5 minute rate 0 bps
Match: access-group 131
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group 132
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group 133
0 packets, 0 bytes
5 minute rate 0 bps
police:
cir 1000000 bps, bc 50000 bytes, be 50000 bytes
conformed 1908 packets, 131969 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
transmit
violated 0 packets, 0 bytes; actions:
transmit
conformed 0000 bps, exceeded 0000 bps, violated 0000 bps
Class-map: CoPP-IMPORTANT (match-all)
0 packets, 0 bytes
Match: access-group 121
police:
cir 100000 bps, bc 20000 bytes, be 20000 bytes
conformed 0 packets, 0 bytes; actions:
transmit
drop
drop
Class-map: CoPP-NORMAL (match-all)
0 packets, 0 bytes
Match: access-group 122
police:
cir 64000 bps, bc 64000 bytes, be 64000 bytes
transmit
drop
drop
Class-map: class-default (match-any)
8980 packets, 685073 bytes
5 minute offered rate 2000 bps, drop rate 2000 bps
Match: any
police:
cir 8000 bps, bc 1500 bytes, be 1500 bytes
conformed 8980 packets, 685073 bytes; actions:
drop
drop
drop
conformed 2000 bps, exceeded 0000 bps, violated 0000 bps
R1#
this way
Class Map
match-all CoPP-CRITICAL-130
Class Map match-all CoPP-CRITICAL-131
Class Map match-all CoPP-CRITICAL-132
Class Map match-all CoPP-CRITICAL-133
note:- add policer for each class
@MHM Cisco World  thank you for your suggestion. I tried it and unfortunately did not work. eigrp still flaps.
ok let me apply policer value you use and see result in my side.
show policy-map control-plane input <<- PLEASE share output after last config you enter
Control Plane
168 packets, 11855 bytes
5 minute rate 0 bps
police:
conformed 168 packets, 11855 bytes; actions:
transmit
transmit
transmit
Class-map: CoPP-CRITICAL-2 (match-any)
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
police:
transmit
transmit
transmit
Class-map: CoPP-CRITICAL-3 (match-any)
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
police:
transmit
transmit
transmit
0 packets, 0 bytes
police:
transmit
drop
drop
0 packets, 0 bytes
police:
transmit
drop
drop
906 packets, 69120 bytes
Match: any
police:
conformed 906 packets, 69120 bytes; actions:
drop
drop
drop
10 permit eigrp any any (90 matches)
the EIGRP use multicast and unicast,
multicast not need arp
unicast need arp
and since the class-default is drop which cause the ARP request/reply drop
and the EIGRP can not know the mac address of neighbor and hence it unicast is drop, this make EIGRP flapping.
I solve it without change CoPP by add static ARP to config, but this not solution because sure there are many other protocol use class-default and action drop can cause reachability issue in your network.
thanks
MHM
katerina86
@MHM Cisco World You are completely right ! Your solution helped me a lot. I actually configured the class map like this:
R1#show class-map
Match protocol arp <<<<
and since i applied this line the flaps stop.
You are so so welcome
