Embryonic connections
Franco_Pieressa
Hello, I'm limiting the number of embryonic conections in my PIX v6.3(4) with the static command, and I have some doubs.
- How can I see the number of SYN that the PIX it's proxing, when is threshold reached? The "show local-host" command doesn't show me that info...
- Which are the disadvantages of limiting the number of embryonic connections with a static command in a PIX? Is there any case where it must not be used?
FP
7 Replies 7
Patrick Iseli
Level 7
Level 7
I am not sure but it looks like it would be that comand?
pixfirewall(config)# show IPAddress detail
local host: <10.1.1.15>,
TCP connection count/limit = 0/unlimited
TCP embryonic count = 0
There is not really a disadvantge to do that, just the risk that if you are to restrictive that you may block sessions and no new session could be established
emb_limit
Specifies the maximum number of embryonic connections per host. An embryonic connection is a connection request that has not finished the necessary handshake between source and destination. Set a small value for slower systems, and a higher value for faster systems. The default is 0, which means unlimited embryonic connections.
The embryonic connection limit lets you prevent a type of attack where processes are started without being completed. When the embryonic limit is surpassed, the TCP intercept feature intercepts TCP synchronization (SYN) packets from clients to servers on a higher security level. The software establishes a connection with the client on behalf of the destination server, and if successful, establishes the connection with the server on behalf of the client and combines the two half-connections together transparently. Thus, connection attempts from unreachable hosts never reach the server. The PIX firewall accomplishes TCP intercept functionality using SYN cookies.
Note This option does not apply to outside NAT. The TCP intercept feature applies only to hosts or servers on a higher security level. If you set the embryonic limit for outside NAT, the embryonic limit is ignored.
sincerely
Patrick
I think the PIX doesn't block connections when I configure embryonic limit. What it do is intercept TCP SYN packets, allowing only legitims connections between clients and servers.
So, what is the disadvantage in configure embryonic limit? A performance penalty maybe?
Sincerely
FP
That is correct. Once the embryonic limit is reached, the PIX uses SYN cookies to make sure the conns are legit. It then snaps the legit ones back to the server it is protecting and drops the non-legit ones.
Yes, this is also right. The disadvantage from the PIX stand-point is that is does require additional overhead. Other than that, there really is no reason *not* to set the emb limit, especially on important Internet facing servers.
Hope this helps.
Scott
Scoclayton,
Are there some quidelines how to setup that for diffrend services lets say web, ftp ...
sincerely
Patrick
So, do you think a value of 1 in the emb limit is a good value?
Another question: I made some test with a PIX configured with a static emb limit, and found that the "TCP embryonic count" (in the output of "show local-host" command) shows the number of embryonic connections the server behind the firewall has. But, how can I see the number of SYN the firewall is intercepting? How can I detect a SYN flood attack in a PIX with the emb limit protection configured?
FP
I will try to answer my own question:
- The only problem that has the use of embryonic limits, beside the firewall performance (the security is his job :-), it's the delay added to the establishment of new connections when the limit is surpassed.
- There aren't any command to view the number of connection the firewall is intercepting when embryonic limit is surpassed, because it use a syncookie method. No connections are created before 3 handshake TCP is completed into the PIX, so neither the command "show conn" nor "show logg" shows them
FP
Hi Patrick:
I don't think there's a general guideline specifically on what you should set your max_conn and max_embryonic conns to for a particular service. However,what I normally do is to monitor the pattern of our network traffic for a while and decide what would be the best threshold we want to set for those services. As you pointed out, "show xlate" and "show local-host x.x.x.x" are pretty useful commands for that purpose.
Even though the PIX will experience some performance hit when TCP Intercept kicks in, we all probably agree that having Flood Defender in place is so much better from a security standpoint than not having it at all. Just my 2 cents.
Binh
