ERROR: BGP is not supported on management-only interface
collinsjl
ASA5525 running 9.5(2)
Entered the route-map
route-map LOCALPREF permit 10
set local-preference 110
Current BGP configuration
router bgp XXXX
bgp log-neighbor-changes
bgp router-id 1.1.1.1
address-family ipv4 unicast
  neighbor XX.XX.XX.161 remote-as XXXX
  neighbor XX.XX.XX.161 activate
  neighbor XX.XX.XX.169 remote-as XXXX
  neighbor XX.XX.XX.169 activate
  network 11.XX.133.160 mask 255.255.255.240
  no auto-summary
  no synchronization
exit-address-family
Apply the route-map
router bgp XXXX
neighbor XX.XX.XX.169 route-map LOCALPREF in
collinsjl
Solution is:
Take the nameif off of your management interface.  Add your BGP commands.  Put nameif back on the management interface
 I did and see the below output.
 sh run router bgp
router bgp XXXX
  neighbor XX.XX.XX.169 route-map LOCAL_PREF in
  no auto-summary
  no synchronization
exit-address-family
Question is why does this work and why did I have to do it for the command to work?  TAC please respond.
Crickets!!!
