Error message when going to Advanced Filter tab
rcrowe
I am running CSPM 2.3.3i S17a. Every sensor that I go to and click on Filter tab, then Advanced filter, then click Add, I get the message "You must select a sensing template in the Sensing tab before you can define any filters.". All my sensors are using a different sensor signature file, and have one selected. This started happening when I had to uninstall and reinstall CSPM. I thought my sensors still have the "filters" stores in packetd.conf on the sensors, so from CSPM I deleted all the filters for all sensors then pushed the policy out to all of them. I then went to the sensor and checked to see if the filters where still there and it did get rid of them. But now when I go to recreate some filters in CSPM I get this message. My sensors are version 3.0(5)S17 and the IDSM is 3.0(2)S10.
rcrowe
Sorry, my IDSM is 3.0(3)S10
